starter solenoids...
soggy_feet
This is the merc starter solenoid that I need to replace on my boat
http://www.iboats.com/Starter-Solen...27.1973--session_id.629814383--view_id.172047
It looks just like any other starter solenoid off any other old engine.
Whats stopping me from just pulling one at the junk yard for $4? Is this actually a 'marine' product?
Current 'noid pooped out on me, so when i want to move the houseboat, I've been starting it with a wrench bridged across the terminals, but thats a PITA. ;)
Re: starter solenoids...
marine parts are shielded to prevent a BOOM in the event you have fuel vapors in the bilge. buy the right part and go boating.
hoot
Pull your solenoid apart and check the contact washer and backs of the post. On some, these post can be rotated 180 degrees and reused. The washer can be cleaned up if corroded.
Ayuh,.... Makes alota sense to go pick up somebody else's Junk for $4.bucks, when the New replacement parts is a budget bustin', woppin' $16.00....
bigred69
I have to agree with Bond-o. $16 is cheep.
ENSIGN
You can use junk yard parts but DON'T LOSE THAT SCREWDRIVER!!!
soggy_feet
I carry a fully loaded tool chest on the boat. There's ALWAYS a screwdriver.
Not because I do things like replace parts with junkyard parts, but because I do things like load my quad/outboard(s)/motorcycle on the bow, and totally disassemble, repair/replace, reassemble as needed.
Thank you hoot, I'll (see paragraph above), and see if it's serviceable or not.
