Starter spins, but does not rise.
Projectus
Hello all,
1992 30hp Evinrude
The starter spins like crazy, but it doesn't lift to engage the flywheel.
Tried gentle banging, and a little WD-40.
Battery is fully charged.
I'm supposed to sell the boat tomorrow night! The guy's 9-year-old is dying to go fishing.
Any help?
Thank you.
pdaly28
Re: Starter spins, but does not rise.
my guess would be a bad starter drive.First I would be sure the battery is fully charged and all connections are clean.Hope this helps.
sutor623
Starters get replaced on here FOR NO REASON every day. My battery terminal cables were corroded and caused this to happen. You could go to advanced auto and get some heavy duty battery terminal clamps, (the automotive kind) and cut back the main power and ground wires a few inches and put them on. I had to run fresh 6ga. wire to a bar clamp to the main harness, cause mine were corroded a few feet up. I bet the current is being blocked by some corrosion. If the starter and solenoid have corrosion on them you could clean those up too. If you do all that without success, tell the buyer it needs a starter or solenoid. No biggie. Also, if the battery was cold that could limit the voltage too.
Projectus
Thanks, fellas.
The battery cable leads are very clean, but any corrosion above that, I don't know.
And I'm hoping that because the starter spins, that the cables are still good. Could some corrosion inside the cables allow enough energy to spin the starter, but not lift it?IMG_1839.jpg
sutor623
Could some corrosion inside the cables allow enough energy to spin the starter, but not lift it?View attachment 137237
Yes!! That is exactly what happened to mine. If you have electrical tape, cut a small groove in the wire right up to the terminal ends, just enough to spread it to take a look. If they look okay, tape em up. You also can take the power wire and bypass the solenoid straight to the starter (WITH BATTERY CABLES UNHOOKED!!!) Hook up the battery, and then turn the key on. (I have a jump start kit that I use, and what I do is turn key on, clamp neg to neg, and pos to pos ON THE STARTER not the solenoid, then turn the jumper kit on for a brief second) If the starter engages, then you have a bad solenoid.
Projectus
Thanks, Pete. I'll try that with the jumper kit.
And I'll check for corrosion like you said.
Thanks again.
And I'll respond with what eventually works for other people who might have the same problem.
rockyrude
If you grab the gear, does it want to slide up and down on the starter shaft?
boobie
The battery isn't hooked up backwards, Is it ???
Projectus
Interesting turn of events...
I checked to see if the gear will slide up and down the pinion, and it does rise up if I turn it clockwise.
Then, I bypassed the solenoid and hooked my booster kit up directly to the starter's terminals. I turned on the booster kit, and whammo! It engaged the flywheel. (I was kind of expecting to need the key in the ignition, and walk back to the console to turn it. Nope. Scared the hell outta me.
So anyway, I noticed that the gear needs to spin clockwise to rise and engage the flywheel. After my booster experiment, I hooked the boat's battery back up, and turned the key in the ignition. The starter gear turns COUNTER-clockwise. Since it's impossible with my leads and my battery to hook up backwards (the posts and leads won't fit the wrong way), I'm wondering...how does a battery reverse polarity???
drumz2129
By any chance is the battery sitting in the battery box backwards? as in 180deg from where it should be?
Projectus
The battery I'm using is usually devoted to my "accessories" because I didn't like the way the battery I usually use for starting looked. So, since it doesn't fit in that battery's box, I just have it sitting on the carpeted rear deck while I'm trying all of this. Can that have an effect??
daselbee
The starter turns counterclockwise to turn the engine clockwise.
sutor623
So either you battery does not have great CCA, your solenoid is bad, or you have corrosion in the system somewhere. Voila. If I were you Id clean up all the terminals and connections from battery to solenoid, to starter, and see if it works. If it does then youre good to go. If not, a simple demo to the buyer and instructions for him to buy a new solenoid will have that boat outta the driveway.
boobie
Usually the only way a battery can reverse it's polarity if it's completly dead and a battery charger was hooked up backwards when recharging it.
Projectus
This battery sat for 1.5 years without any charging until 2 days ago. And I suppose it's possible that I connected it backwards to the charger. I'm not claiming any perfection!!
daselbee
That's a reach. Clean the terminals, check for corrosion under the insulation, don't forget the ground, just as sutor says.
Load test the battery at autozone or equivalent.
Projectus
Wait, when I hooked up the booster battery directly to the starter's terminals, and had success, should I have first removed the leads already connected the the starter? (the leads coming from the solenoid?) I didn't. I didn't have the boat battery connected at the same time as the "jump start," but still. Should I have disconnected those lead wires during the "jump start?"
Projectus
Ok, sorry. I'll clean the terminals, and check for corrosion.
Thanks for all the help.
