Re: starter spins freely no engage
Bigcash, The starter bendix is engaged through cetrifugal force and returns via spring load.The The pawl or follower needs to be target lubricated. Meaning, a drop of oil in the right place is better than two along side.A few light raps with a piece of wood or screwdriver hanle may break it free after oiling.You should be able to manipulate bendix by hand and get it to move toward flywheel.It may require removal and disassembly to free up ,depending on how stuck it is.Good luck.
