G8rfreek88
- Joined
- Jul 10, 2021
- 2
Good evening. I am in the process of replacing the tilt/trim relays on my motor. So a couple days ago I disconnected the wires(4 of them) attached to the bottom two bolts of the starter, to access the relays, and like a true noob, I didn’t snap a picture like I should have before disconnecting them. So here I am, relays replaced, and in need of some help as to which bolt each wire should be reattached to on the starter. Here is a photo of said wires, the 2 circled in orange are coming from the wiring harness off the relays, the blue circled wire appears to be attached to the motor casing, and the white circled wire is the one that goes back to the battery. I appreciate any and all input. Thanks in advance.
