Starter wiring
oxmax360
Hi all,
Does anyone know how the ele. starter on a 25 hp 1992 mercury should wire up, if someone knows please post pics, or wire diagram, the guy I bought the motor from just cut all the wires out and I really don't have any thing to go on as to how this should be put back together, Thanks
Mi duckdown
Re: Starter wiring
Serial number would help. tiller button start? or what? pics would also help.
Quite vague
oxmax360
Re: Starter wiring
Sorry about it being vague, It is A tiller button start, cant post pics for some reason?, serial number is 615j161, Thanks for any info.
carholme
Re: Starter wiring
Can you double check that s/n as it would not have a j in it. Starting with the number 6, this would put it in the '80s, not 1992. Is is a 2/3/4 cylinder?
Gerry
oxmax360
Re: Starter wiring
It is the number I found on the cover, and it is a 2 cylinder, thanks for the info, I am new to this motor and it has a sticker on the cover with that number and 1992 on the same sticker maybe wrong info, or some type of inspection sticker? dont know for sure.
oldman570
Re: Starter wiring
check on the transom bracket for the SR# and modle of the motor. It should be on the side.
Oldman 570
oxmax360
Re: Starter wiring
I Did check there it's wore off :(, but thanks.
carholme
Re: Starter wiring
This would be the s/n range for a 1992:
0D082000 thru 0D181999
Range for the s/n starting with 6:
5942041 thru 6185158 (1982)
Gerry
oxmax360
Re: Starter wiring
Thanks for the info, will keep looking for the s/n but would the wiring be the same, I need some type of diagram to go on,thanks for any info.
