Old starter occasionally started just spinning when turned on, and would not engage the flywheel to start the motor. Eventually got to where it would just spin. Solenoid clicks when turned to start, just once, but still would not extend the shaft to engage the flywheel. Thinking it was the starter,put a new one on. First time it cranked the motor right up. Second time, it cranked it up. Third time, just spins like the old one. Got to engage the flywheel a couple of times, but now all it does is spin.
Charged the battery, and no change. Lubed the shaft. No change. Jumped the poles on the solenoid, still just spins. Cleaned all the connections, no change. Checked voltage to solenoid from battery and it is good. Voltage at starter with switch turned to start is 16.
I am thinking starter is bad. Any other ideas?
