bluegillfisher
Thread starter- Joined
- May 14, 2007
- 26
Hello
I'm new here, and to boat motors. I just got a jon boat with 1989 25 horse evinrude with pull start(E25RCEM). I don't have manual on how to start the motor. I did get an aftermarket manual on how to work on evinrudes.
There is a knob that looks like a choke on front of motor. It moves in and out. There are hoses attached to it and the carb. If I pull it out, it slides back in.
If I pump it in and out gas comes out of the hose(I pulled it off.)
When I start the motor I have to put my hand over the carb to get motor going first time. I am working through cleaning carbs and fuel pump, because motor surges when running and then dies. I can restart and then it surges and then dies. I will do compression test today, but it is hard to do when motor does not run run right. And I wonder what should I be doing with choke like thing.
As far as running motor out of water--how long can I run with muff thing? Is putting lower motor in tank of water better?
Oh, and what does WOT mean?
Thanks for your help,
Mary--who rather be on a lake fishing
