PensacolaJason
Thread starter- Joined
- Oct 23, 2011
- 176
I'm looking for advice on my outboard issues. I have an 50ph Johnson that just has issues idling and running....always has since I've had it. It's been to three different mechanics in my area and each time I get it back it runs for maybe a day and then I have issues come up again.
Today I ran it on the muffs before taking it out and it idled fine. I was able to get it in and out of gear with no issues. I dropped in the water and it started right up and idled and went into gear. After running for about 100 yards we noticed that it wasn't finding a cruising speed like it should. It would either run really low or you'd have to mash the throttle down and then it would move too fast. Trying to find a nice middle-ground was impossible. It's almost like there is no medium cruising speed at all now. It finally died and then we had trouble getting it started at all. After a while of tooling with it and choking I got it to stay running and on the way back it died twice while trying to find a speed between idle and super-fast.
After I got home I put it back on the muffs and had issues starting and keeping it running. A day later I went out again and now it seems to run just fine on the muffs, so I'm baffled.
Most of the parts on the motor are brand new (fuel pump, head gasket, spark plugs, coils, power pack, starter solenoid, primer solenoid, starter, wiring...). The carbs were just rebuilt and I'm using fresh gas.
Here's the video of my issue - http://youtu.be/dEYyFtmM1TI
