jmarty10
Thread starter- Joined
- Aug 6, 2007
- 560
Hello all - I have a 18 ft 3.0l mercruiser alpha one drive. I'm still fairly new to boating and will be towing boat for first time this weekend
I know that before I make the hour trip to lake I should start boat to see if it works. My first question: the proper place to pute muffs is on the outdrive where the inlet slats are and then connect hose to muffs and turn water on correct?
My second question: I usually start boat when completely in H20. Today, with muffs and water on, I pulled throtle out and put throttle all the way down and tried to turn over. It just cranked. I put throttleback into neutral position and it turned over nicely. What is thecorrect way of starting the boat/giving it gas with the throttle. I've been told a couple of dfferent ways but dont really know if this is correct?
Also, is it ok to put it in gear and spin propeller for only a couple of seconds?
Thanks
Thanks
