For my 1991 Mercruiser 5LX Thunderbolt powered boat I don't have any operators manuals. I would like to know what a 'normal' starting procedure should be. When cold, I have to pump the throttle a number of times while cranking before it starts.
The last time out, After a 5 mile run, I shut the engine off for about 30 minutes. When I tried to restart it, it just cranked on and on. I tried pumping the throttle, until I was sure it was flooding. Finally, I put the throttle all the way down, and it started.
I'm probably trying to start it incorrectly. Is there a recommended starting procedure for this carbureted engine? If so, would someone please tell me how it should to do it?
If this sounds like a carburetor problem, would someone help me identify the carburetor, and I'll try rebuilding it or replace it, if I can find a rebuilt carb. Thank you very much for your help.
-Dale-
-Dale-
