sheboyganjohn
Thread starter- Joined
- Aug 2, 2005
- 753
Got the starboard engine aligned and went to put the drive back on and could not get it on. Every time I went to push it into place , the shift arm would pop out of the shift cable. Doesn't make any sense since it is rotating into the center of the drive, I would expect it to rotate out in the shift direction if there was an issue. It was starting to get dark out so we gave up. Will get back at it sometime this weekend. My guess is that the shaft may be sitting just a bit low. may need to lift it up a bit. I, well we, had the kid helping, were trying to do it with the back end of the boat over the grass. I am going to pull the boat forward onto the parking area so we can see thing a bit better and not have to worry about the drive sinking into the lawn as we are working.
In the mean time, more patching and painting on the house. I will be so happy once the refi is done and I can focus on the boat, or should I say boats. About time to bring the duck boat home. Still contemplating the power head swap on the mud motor this year. Will need to do some major mods to the frame to put the 25 hp Kohler engine in place of the 16 hp Briggs.
