Starting Old Evinrude for 1st Time in 6 years
Wateree
1st time poster seeking advice
Getting ready to start a 1972 115 hp Evinrude - motor has set up for about 6 years with no activity or run time during the period
Is there any sort of checklist or advice that I could refer to in staring motor that has set up for such a long time - want to be cautionary not to destroy the motor.
Thanks,
will941s
Re: Starting Old Evinrude for 1st Time in 6 years
There is a post on hesre called "awakening a sleeping outboard". If I had time I would find it for you. It tells everything possible you would need to do, check and perform to get a OB back on the water again after a long sit.
Willyclay
Welcome to the iboats.com forum. The experts here, which I am not, can help you with any question about your boat, motor and trailer. The link below will get you started:
http://forums.iboats.com/showthread.php?t=158086
There's a lot of good info in the FAQ's at the top of this forum. Good luck!
