NMBuzz
- Joined
- Jul 12, 2009
- 40
I have a 1993 Larson 17' with an I/O 4.3L Mercruiser 2bbl/ Alpha One drive.
I have a problem with the starter engaging reliably.
A little (pertinent) history- when I bought the boat I had a shop change the gimble bearing, exhaust and shift bellows, and impeller. The starter was frozen so I had them go ahead change it out (new ARCO starter with offset bolt pattern). Long story short... after getting it back from the shop (to get water out of the fuel tank, and do other repairs) I was able to start it but the starter sounded like it was grinding. I noticed the outer starter bolt hole on the block is half there which exposes half of the outer starter bolt, however it does tighten and holds 50 foot pounds of torque.
Of course the "shop" knew nothing. Not sure, but NO more business there...
The continuing problem I am having is this. When the motor is cold I can get the starter to catch and start, but it grinds. When the motor has been running and is hot, the starter grinds a lot worse and sounds like it is not meshing with the ring gear. The bolts remain tight and there is a slight movement of the starter but it is grinding like heck! I have pulled the starter and I found the flywheel teeth to be chipped in places, and slightly ground down in others and OK for the most part. I tried shimming the outer side of the starter (.120") to get the bendix in tighter and it seemed to help, but not when it is hot. I can turn the harmonic balancer to get past the "bad spots" on the ring gear, but when it is hot the starter just won't catch or engage and it REALLY grinds. If I let it cool for a few hours I can "get lucky" and it catches (but still sounds "bad").
I am going to pull the motor and replace the ring gear, but I am wondering about the broken bolt hole. I cannot believe I may have to change out the entire block for this one thing. On the other hand it makes more sense to me and is cheaper to change the ring gear, and rebuild the starter drive gear and get a better look at what is going on in there..... The starter had slight movement initially and I thought a good thing to do would be to add additional support (due to the broken bolt hole) to the starter so I made and installed a starter brackets for it. Seemed to help...
I have not pulled the starter back off yet, but I plan on finding a worn down drive gear (which I aim to replace). Could the slave solenoid up by the carburetor be part of the (thermal) problem?
Any thoughts on this?
Sorry for the long post, but I want to give as much information and history as I can think of. I am new to boats but not to motors and such.
