I have a 1990 90 hp Johnson. If it's been sitting for a day or more, it takes 30 secs or more to start (after I prime the bulb hard). If I stop, then start again 1 hr later, it starts right away. Once started, it runs flawlessly from idle to WOT. No stalls, or hesitation.
Sometimes, I get a no oil warning (beeps every sec) after I start, it goes away after I revv it up.
Just had a shop overhaul the carbs. Just replaced all fuel lines and tightened the connections.
I suspect that because the VRO is old, the crankcase vacuum during starting is too weak to drive the fuel pump properly, but when running, the vacuum is strong enough.
Any opinions on this?
