starting problem with 25HP Johnson
dfrants
just got a 1995 25hp johnson. won't start unless you spray starting fluid into carb, once you get it running and warm it up, i can shut it off and start it up right away. but if you leave it sit for a few minutes and cool down, it won't start again. also if you try to prime it, it seems to flood and soak the spark plugs. I checked the compression and it is an even 125psi and spark is good. what is the factory carb rich/lean setting?
can these style primer solenoids cause starting issues?
thanks, Don
boobie
Re: starting problem with 25HP Johnson
How did you check your spark ??
I had a 140 mariner that did the same thing and the guy that did the work on it said it was cold natured but i think it has something to do with the feul we never did figure it out but i wouldnt keep spraying alot of starter fluid in it i hear bad things about it
DJ Grimes
BE AWARE
Starting fluid in a 2 stroke is a bad idea due to the no existing lubrictaion
Too much starting fluid drys the cylinder walls which will lead to seized engine
trying choking it for a second then turning it without choke if still wet plugs looks like its time to break out the electric tape an find out why its not firing
two strokes are just like wives
give them what they want theyll love you forever
give them something they dont want itll cost ya
dfrants
i have an inline spark tester. it showed a bright spark on both cylinders.
boobie
Will it jump a 7/16 " open air gap ??
