Starting problem
seth6025
I have a 1978 80 hp mercury outboard that was working fine when I put it away last season. I got it out this year and it won't start. Just keeps turning over with no sound of wanting to go. Now I have pulled all the plugs and they are getting spark but the top two don't seem to be wet at all? No fuel getting to them?? The bottom two seem to have some gas on them but not much. I also noticed that there is gas sitting inside the motor case that looks like it came out of one of the breather holes that go to the carbs. Not sure if it is flooding on the bottom and no fuel to the top or what. It worked fine when I put it away, I don't know what could of changed????
Any idea's
Laddies
Banned
Re: Starting problem
Should have run the carbs dry, clean them and you will be good.
