Starting problems 35hp 77
eric e
Well the motor I have, a 77 evinrude 35753h, I finally got everything hooked up , changed the plugs and have attempted to start. It will run for about 1-2 seconds, then shut off. It will do it again, and again, and again. Last night, I got it to stay running barely, and it almost seemed like it was idling too low.. Not sure though. Could it be the carb? If so, does anyone have a link or detailed instructions? Cna it be cleaned on the motor? Thanks for any help.
James R
Re: Starting problems 35hp 77
Must remove the carb and dismantle it per the manual. Dont use the so called spray carb cleaner .It can damage parts. Use the Carb Kit from the makers of Gunk products. Follow the instructions. Can be obtained from Advance Auto. I have used this for several years on many motors and it works.
bonz_d
Have you tried opening the throttle a little bit? My 35 starts hard cold w/o the throttle cracked open a little and the choke closed.
eric e
Well, I got it started, but the starting solenoid has been "clicking" then about every third time, it would engage the starter. Well after I got it running a bit, it will not "click" or do anything. I jumped the solenoid, and the starter would engage. Any recomendations on where to get a new solenoid?
dade61782
check and clean all your cable connections sounds like a dirty or bad connection also check your nuetral safety switch
eric e
I cleaned all the connections yesterday. I have not been able to get ahold of a manual yet, where is the neutral saftey switch normally located? Thanks.
dade61782
on my 79 it is next to the fuel pump with a yellow and red wire going to it
tashasdaddy
depending on controller, could be in the control.
eric e
My setup does not have the control box, just wired into the ingnition on my boat.
eric e
Ok, after searching, and reading this post, it looks like it may the saftey switch. I am getting 12volts at both white wires. It talks in there about grounding the saftey switch. How would I ground it? Thanks..
eric e
Alright, I am wrong again. It was the throttle advanced too far, but the solenoid is still doing the "clicking". Is there another way to test it?
