GBOverKill
Thread starter- Joined
- Mar 17, 2009
- 26
Hi Folks! I'm a new boater and recently purchased a 1994 Bayliner Capri 1700 with a Force 120. I've already read alot of the threads on here and you've already helped me with a couple issues
Thank you!
Now here's the deal....
DAY 1:
After filling up the tank 1/2 full, adding the corresponding oil, and a can of Seafoam....I had the boat out last week for the first time...well not really out since it never made it off the trailer
. The engine would start up, idle, put once put in gear it immediately stalled..... After reading some threads on here I adjusted the idle up just slightly and....
DAY 2:
Took the boat out after adjusting the idle and it ran perfectly. Cruised around for about 1 hour 1/2 to WOT. Handled great!
DAY 3 (Today):
Figuring I'd spend a good part of the afternoon on the water (it hit 66 degrees here!)...I filled the gas tank full, put a corresponding oil mix in, etc. Unloaded it off the trailer, docked it by hand, parked the truck, walked back and it won't start! I ended up totally draining the battery in my quest. Back onto the trailer and home it sits.
The only things I did differently from Day 2 to Day 3 is: fill the gas tank to full and changed the spark plugs.
Now from my reading on here....the first thing I need to do it get a 'cranking' battery. I've been running/starting everything off a deep cycle battery that came with the boat?????
Any other suggestions?????
DAY 1:
DAY 2:
DAY 3 (Today):
