lonewolf41
Thread starter- Joined
- Jun 28, 2013
- 174
My "new" boat had been sitting for the last 6 years. It has the 1998 4-cylinder 30GSMBY Volvo in it (picture of tag attached). I've got it running now but am still leery of it until I get a few trips under my belt. Took it out for a couple of hours last weekend and it ran good. Checked the oil after and it looked good, a little darker after running for a while, but still nice and honey colored. Took it out again today and after an hour or so, we came in due to another issue. I checked the oil and it looked milky (picture attached).
I thought that it might be the exhaust manifold/system so I took it off and you can see what I found. It looks like rust on the wall and water sitting in the exhaust side of the manifold. I attached pictures of both part surfaces. I am assuming that water is going into the exhaust at the riser connection and then sitting in the exhaust port(s) eventually leaking past the valve, piston, and then into the oil. Does this seem like the most likely scenario based on the evidence? Any other things/areas to check?
TIA,
-Keith
TIA,
-Keith
