floatingwoody2006
- Joined
- Feb 2, 2006
- 500
Had it out on the water for a couple hours today, and it seems to run ok, but not perfect. I am familiar with the typical exhause leaks on them, and that's what i believe is causing the occasional "sneezing" but otherwise, does run ok. I was adjusting the carb while underway to see if i could even it up a bit. When it started bogging at the end after i got the carb as close as it liked it, i gave the fuel bulb a squeeze to see if it may be the pump, but all that did was stall it out. Is that supposed to happen? if i squeeze would it actually flood it? It has a fresh carb cleaning done correctly, and all electrical is fine. Im starting to dislike the motor, but another is not an option at this time. It did re-start so i could get back to shore. Thanks. oh.. And i have heard some people drill some small holes in the cowling and that helps a bit.. Where would be the best location to drill these? Thanka again.
