Stator 6hp non standard
Is the brass insert loose in the aluminum plate ?----This would not be my approach to this repair.----Is there a 6 digit number on that aluminum plate ?
Coq Circa
I've done it and it seems to work realy well. A clonky old engine but hey! I'll put a video up on YouTube, I dont think I can put video up here.
Coq Circa
Racerone the brass ring wasn't loose in the stator plate. The problem was play between the brass ring of the stator and the powerhead.
tphoyt
I always grit my teeth when I see a motor running wot in neutral. It’s just not good for the motor.
Glad you get her going.
Coq Circa
I know. I considered not posting that as I knew it would hurt. But I wanted to see if it would clang. It needs to go for a run on a boat.
Coq Circa
It was soooooo tight I had to use a pliers to twist it. So I took it appart and changed the washers. For the moment I'm happy its easy to turn. I'll tighten it a little before I put it on a boat.
