stator A34 or A35 ?
bluebear57
can anyone tell me the difference between a 398 5454 A34 stator and a 35,and will they replace each other. thank you will they both work on a 89 mariner 150?
Laddies
Banned
Re: stator A34 or A35 ?
They are interchangeably in the CDI manual but not the Mercury manual, which mean that either the wires are a different length or the lamination is a different thickness as mercury built 1/2 and 5/8" lamentations. CDI builds 1 stator with the longer wires and a 1/2" lamination that will work on either engine. I have do not have a mercury price manual the goes beyond the A34. May be someone else can help you or you can call a Mercury dealer.
Faztbullet
A 1989 motor should have the 40 amp stator and these stator #'s you listed will not work.........
bluebear57
the boat is a 89. but the motor could be a 87 would it still be a 40 amp?
Fun Times
We'll need your engine serial number to know for sure what engine you have.
The 89 should be a 40 amp.
174-9610K2: Stator
The 87 should be a 16 amp. 174-5456-16: Stator
The two numbers above (398-5454A34, 398-5454A35) coincide with the 16 amp.
Your other thread on this subject brought me here to see what kind of engine you have.;)
http://forums.iboats.com/mercury-mariner-outboards/87-89-mariner-stators-595902.html
