What should the stator output be when you check across both yellow wires? I am getting 16VAC @ idle and 18VAC @1500 rpms. The output on the rectifier (new) is 13.5 VDC @ Idle and 14.3 VDC @ 1500 rpms. Wonder what it would be @ 4500? Stator ohms out @ 1.5 both cold and warm and open from lead to ground (book says thats good). Maybe I am looking for ghosts but I am worried about going over the 16 volt max on the powerpack. After losing one pack but it never hurts to ask.<br /><br />TIA<br /><br />Russ In Texas
