countvlad
Thread starter- Joined
- Jun 29, 2009
- 439
the motor is a 1989 120Hp Johnson.... i tested the timer base and then the stator... timer base was 43 ohms which is spec...
but the stator reading was 507ohms... which according to the manual its over the limit... could this be wrong since i used a digital meter or stator is bad?
when i checked the stator i left the two yellow wires hooked up. could that give the higher ohm reading?
