Stator Test 40 hp Mecury
I tested the stator on 40 hp mercury by swapping blue with blue/white on switch box. Spark changes fron 1 and 2 cylinders to 3 and 4. Does this mean stator is bad or could the problem be coming from the trigger? Original problem is no fire on 3 and 4 cylinders.
Thanks
Faztbullet
Re: Stator Test 40 hp Mecury
Low speed coil defective on that side of stator.....
Rodbuster
It's mounted on the stator and you can only change the stator.
1nebel0
Time for a new stator as previously stated by fastzbullet...
marzoid
hey you might also want to try changing the spark plug wires
run the good wires to where ur not getting spark
