Question about stator to regulator wiring. There are 2 yellow wires that come from both stator and the regulator/rectifier. Can any yellow wire from the stator be plugged into either of the yellow wires on the reg/rect and vice versa?
The reason I ask is I was troubleshooting a tach/regulator/rectifier issue and had both yellow wires unplugged. I plugged everything back in but am not sure if they are as before, and if that would cause any problems. Basically, are those yellow wires interchangeable? Thanks for the help.
