forty5goingon65
- Joined
- Aug 3, 2009
- 81
i put gas in the tank and after it sat for awhile the pressure built up and it started to leak out of the quick connect at the tank so i took off the lid and released the pressure so then i tightened the cap and hooked it to the motor i let it sit for about 10 minutes it did not leak but it sure had a lot of pressure built up in the tank when i took off the cap again can some one tell me if that is normal does the old steel gas tanks have a pressure release like a rad at a certain pressure or is the vent on the cap plugged i didn't try to start the motor with all that pressure i was afraid to, not sure what would happen thanks
