What a great feeling to get that done. New 16' dual steering cables for Vindicator 200. Not hard at all. Mostly getting the courage to pull the engine. My steering is very easy and smooth. I had good service from the parts supplier in New York. I noticed the instructions warned not to use any grease since the parts were already greased and there is supposedly an issue about mixing greases. Really? Install the new cables without grease? Also, there were no instructions about centering the wheel. So I guessed, and I'm off by about 20 degrees. No big deal. I'll probably ignore it. I could lie on my back and loosen the eight screws/bolts and start over but I'm not too motivated presently. Good is good enough, but if there was a trick I should've used, I'd like to know. thx
