Steering alignment
cowboy_bob
Hello, I have a question about aligning my steering wheel so that the OMC label is at 9 and 3 versus now at 8 and 2. I have a piston type cable (if that's what you call it) not the clothe line type cable. Would anyone know how I can align this more. Thanks By the way, its on an Evinrude 30hp if that makes a difference.
cr2k
Re: Steering alignment
If you have a rack and pinon set up just get the motor straight and take the rack lose and straighten the wheel and replace the rack.
EricJRW
I was searching for this very same answer... How do you loosen the rack? I looked, and did not see anything obvious. Attached is a picture that shows some of the steering mechanism. The photo was taken for the gauges, so it's not the greatest shot of the steering.
Thanks
MH Hawker
It may also depend on the steering wheel shaft, some are splined and some have a key way. Mine has the key way and I had to losen the cable and put it in and out a few times till it was on center. Then I had to adjust the tube at the motor to fine tune it.
Eric, you do not have Rack and Pinon steering. Your's is rotary.
Bob if you have R&P steering there should be some bolts holding the rack to the pinon. Remove them, straighten the wheel and replace them.
EricJRW
Thank you... I imagined it worked like R&P, guess I need to look up how rotary works now. :confused:
