Steering angle
halas
What is the correct allowed maximum angle of the propeller shaft?
Yacht Dr.
Re: Steering angle
Hello halas..
I dont understand your question m8..
Do you mean how far you should be able to turn your drive unit in relation to the bell housing ?
Reason for the question might help some too..modifications ?
YD.
ondarvr
Re: Steering angle
I don't think we understand your question all that well. But you want the motor to turn as much as possible from side to side and it needs to be even on each side also.
halas
Re: Steering angle
I don't think we understand your question all that well. But you want the motor to turn as much as possible from side to side and it to be even on each side also.
Sorry for not being more specific.
Yes I was wondering: is there a minimum or maximum
travel of the outboard to the left or right that provides safe and practical steering?
My steering allows 20 degree to the left and 20 degree to the right from center. Is that enough?
ondarvr
Re: Steering angle
Remove the steering link from the front of the motor and then turn the motor side to side. With it connected it should turn about the same amount. If it only turns as much as what's shown in the pic, then something isn't right.
