I have a 99 Javelin Renegade 18 with a 150 Johnson for starters. I had it equiped with a jack plate to start off with and the steering has always been stiff from day one but nothing like it is now. It has always been rough a low speeds but only took one had to move the wheel and loosend up fairly well once opened up a bit and drove easily.
It all started this last spring when I noticed a little extra play in the steering but I didn't have the time to mess with it since I had to head overseas for a bit in Mid May so the boat sat all summer long under cover until this October. I ran all around the boat cleaning a greasing everything in sight and headed down to the local lake for a spin and fishing time I'd misssed out on. I immediatly noticed a drastic change in the steering as soon as I untrailered it. It takes two hads to turn the wheel in either direction. I don't just mean its a little tight, it really takes a good bit of presure whether moving or sitting still. It moves to the right with one had for about a third revolution but if you want to go past that or move to the left it takes two hands and some strength to make it turn.
Yes, I greased the fitting on the lower unit where the motor pivots untill the grease came out. I also took the steering cables loose from the motor one at a time and cleaned of the old grease and regreased as much as possible but none of this has helped me out. I've been out several times since and played around with the system with no real results. I also have more play in the wheel than ever before. At high speeds I have 2-3 inches of play and seems to be getting worse the more I drive. I also have a slight poping sound when moving the wheel when torqued to the left back to the right at near top dead center. What next and do I need a book? I have a dual steering and I think its a Teleflex system. Any thoughs or ideas would be appreciated.
Thanks.
Thanks.
