steering cable connection on motor without tilt tube?
charger_1
Hello all,
First time pontoon owner as of Tuesday. The toon is an older 1983 Kayot Commodore 5924 24', and is in PHENOMENAL condition for it's age. The upholstery is in dire need of recover, but the rest is absolutely solid, no cracked welds, toons are pristine (not even a scum line). Purchased it for 500, no motor, no trailer.
I had in my possession for the past couple years a great running 1971 Evinrude 85 horse, manual tilt/trim, electric shift. Purchased that for the price of the prop (buy the prop for 25 bucks, get the motor free). Mounted up perfectly to the pontoon. Here comes the problem:
Upon trying to connect the push-pull steering cable (rotary I believe), I quickly discovered that the motor's pivot is a simple bolt, not a pivot tube. Turns out Johnson/Evinrude did not add the pivot tube until 1973. Here is what I've learned so far:
If I don't intend on tilting/pivoting the motor, no problem, just affix the steering cable to the transom and connect a connector rod. BUT I intend on having full tilt motion on the motor.
There are add-on brackets you can attach to the transom, that hold the pivot tube (or cable housing without the pivot tube), at the motor's clamp area, and have it function in that respect. BUT the pontoon's transom is barely wider than the motor, so the cable can not be made to fit down into that area without severe kinking. Also, I can not attach such a clamp above the transom area since the motor's powerhead does actually recess slightly into that area when fully raised.
Here are a couple ideas I am considering:
Drill a hole into the side of the transom, as high as possible, allowing the cable's pushrod to pass through into the transom area, just under the motor's pivot point, and using the connecting rod as normal. This type of installation would also require me to add a bracket externally of the transom to hold the aforementioned tube bracket (since the length of extension and retraction of the cable is nearly the width of the transom).
Boring the holes larger through the motor's transom bracket and the pivot bracket to allow for the pivot tube to pass through. Without doing the necessary measuring, a visual inspection leads me to believe there will still be plenty of material on the brackets of the motor, as compared to my 1981 Evinrude 85hp on my other boat, that does have the pivot tube in place.
Lastly, a long-shot, much more expensive than the other two options is to locate the full tilt and turn bracket from a 1973 Johnson/Evinrude motor that has the provision for the tilt tube assembly, and see if I can frankenstein it onto my 1971 motor.
I am prepared to have to custom-make my connecting rod as necessary from cable pushrod to motor, and the idea of the hydraulic steering system, although perhaps the BEST solution, is way out of my budget.
Has anyone encountered this before? If so, what was your solution? Any thoughts to my ideas? (I'm leaning toward the hole in the side of the transom, for ease, speed of deployment, and simplicity)
Thank you for taking the time in reviewing this
Jeremy
charger_1
Re: steering cable connection on motor without tilt tube?
The hole in the transom isn't going to work, the cable can't physically bend in that manner, even though it is just a couple inches from the pivot point of the motor.
I noticed that the clamp on the motor has holes every 3/4", and I have 3 more holes to choose from (raising the motor) so I have decided, at least for now, to make a 1 1/2" spacer under the motor clamp, that slips over the transom, like the trim does now, thus allowing the steering cable to slide under the motor clamp. This should position the cable within about an inch from the ideal pivot point, much closer than the add-on clamp would have positioned it had I been able to use it.
I found that the inside diameter of black iron pipe is identical to the inside diameter of a pivot tube, and fits nice and tight inside 1" square steel tubing. After cutting a 12" length of the pipe, and slipping it into a 14" length of square tubing, I welded the gaps on the one end, and with the extra square tubing on the other end, I can attach a couple set screws to secure the cable in place. I will be adding a second piece of square tubing, 17" long (to match the width of the trim piece on the transom) and will be welding this along side of the first square tube assembly. I will finally be adding 1/2" of steel below the two square tubes to get my 1 1/2" rise necessary. Finally, I will be adding two "skirts" of sorts, made from 16 or 14 gauge steel (what ever I have on hand) to the new assembly, allowing it to slip over the transom, down far enough where the clamp bolts pass through, so when it's all said and done, it will be one secure, strong spacer, allowing for the steering cable!
I don't believe the 1 1/2" increase in height will cause many problems with the prop in the water, it seems to hang too low by a couple inches as it is. The ventilation plate will still be almost even with the bottom of the pod (maybe 1/4" above).
CHUNKS1140
Charger you got any pictures of this i have the same problem just do not understand what you did for sure.
plizert28
I would also like to see some pics. I just purchased a used motor and I am trying to figure it out myself.
Thanks,
lmuss53
Only thing I would do differently is thread the end of the pipe so you can run the stock nut on to hold the steering cable.
I can't see how you'd get set screws tight enough to hold without collapsing the tube.
