thebulldog
Thread starter- Joined
- Oct 11, 2009
- 48
Hello team !
I have run into a snag while trying to connect the steering cable shaft to the motor mount steering point ....... the shaft that extends to steer the motor is too long. If you notice in attached photo, the left side of the cable also has two nuts that should be tightened by a nipple (plastic or brass ? ) that would fasten the cable assembly onto a solid point on the transom side pass through hole. The centre circle shows the engine steering mount point, the right side circle shows the shaft at its shortest length.
The question(s) should the steering cable be fastened to side of transom ?
Is there some sort of fix to make cable shorter, or the end point hole where the bolt go's through (to motor) be modified ?
Or should I just sell it and Give Up ??
Many Thanks ....... Bulldog.
