Steering cable lubrication?
Boomyal
What gives? My factory manual clearly shows a xerk fitting on the steering cable a few inches from it's terminating fitting at the back of the transom. This is for a '76 Merc 888 setup.
I can follow the cable sheath right up to the metal end of the cable and can find no such fitting. I think everything is original.
Are there variations? Am I missing something?
Don S
Re: Steering cable lubrication?
That zirc is ONLY on the Mercruiser cables. If you have a cable from a different manufacturer it probably doesn't have one.
Boomyal
Gotcha Don, come spring I will see if I can find a name on the steering components.
Probably a Teliflex or a Morse...........
Either Way,.... The Cable is a Non-Servicable Part.......
Pretty much for the same reasons that you Can't service Most Hyd. Lines nowadays,.......
Even thing is Crimped, instead of Screwed..........
Boomyal
bond-o said:
Everything is Crimped, instead of Screwed..........
That is all except for the customer, huh bond-o?:%
Ayuh......................
