steering cable removal
Dawgs
ok im taking the motor off the boat...1990 johnson 150...the wiring is self explanatory...as far as the steering cable...are there any tricks to disconnecting it? or do i just loosen the bolt and pull it from the motor?
Dawgs
Re: steering cable removal
ok lemme explain. i am replacing an evinrude 150 with a johnson 150...i will be using att my existing hook-ups. i would like to use the existing steering cable as well......how should i do this? how exactly do i disconnect the steering cable from the motor..its not in the repair book
noelm
I guess it is just "standard" steering, you just undo the big nut on the tilt tube and remove the steering link from the end, and pull the cable and solid bar piece out, it is easy as long as it is not rusted in.
Dawgs
what do you mean "steering link"? how do i remove that?
bang4dabuck
I assume this is NOT a hydraulic system. Shoot some grease into the grease fittings. Both of them on TILT (STEERING) TUBE. Turn steering back and forth a couple of times and trim the motor up and down a couple of times, This is to spread the lubrication around. Disconnect steering arm that is connected to end of steering ROD (???). On the other side, there S/B a large nut on whatever side that the steering cable goes into. I am thinking it is an inch or maybe larger (wrench size needed). This is threaded on to your TILT TUBE and will have to be decoupled. Now just pull cable out of tilt tube. If it won't readily move after nut is decoupled and you or some big guy yanks on the steering cable, you are going to have to use a large hammer that has some weight behind it, at least 2 pounds. You are also going to have to come up with a long pin once you get that steering rod in the tube. If you can find something that will fit in the tube made of hard plastic or wood that would be preferable. I didn't. I ended up with a long carriage bolt from Lowes and tried to minimizing damage by putting a rag between the pin and end of the steering rod.
Dawgs
ok i have 2 large nuts on either side of the tube....do both of them come off or just the one where the cable comes into the tube?
Dawgs
so in a perfect world if i unscreww the large cable side nut...the cable should pull right out?
jonesg
Its awkward, on mine I have to lift the engine onto a cherry picker hoist then slide the cable out as I pull the engine away, some boats just don't have enough room at the transom to pull the steering cable clear.
bang4dabuck
TD thanks. My old merc did not have fittings back there but thought that OMC was a different drummer. Will have to put my Steersman nut back on. Never the less it should be beneficial to lube it up by hand as per the manual (expose steering shaft as much as possible by turning steering wheel to furthest point and put some good grease on there and rub it all over). Sounds XXX
