Boatpuller
Thread starter- Joined
- Jun 12, 2018
- 28
Hello, I am trying to replace my steering cable on a 1993 alpha one gen II. I've loosened the nut and unhooked the rack from under the steering wheel, I've also removed the pin from the yoke that attaches to the lower unit. I can pull the cable out about 6 inches but then it stops and won't go any more. I figured my next step was to remove the tube with the cable and try to remove it from outside the boat. See photos below. I removed the nut that holds the adapter to the valve assembly. I assume that the adapter should pull off the valve assembly. It also seems to be stuck on there. I might have to use a puller to get it loose from the bolt sticking out of the valve assembly. Any thoughts would be appreciated. I assume that the cable end is corroded, keeping it from being pulled from the tube.
