Steering cable
rob 135
Can I remove steering cable without lifting motor off transom ? I don't think there is enough room to pull cable out . I was thinking drilling another hole to pull cable thru.
Barnacle_Bill
Re: Steering cable
Some boats you can and some you can't. It might help to know what you have.
boobie
Re: Steering cable
Still best to pull the motor off of the transom. Or, disconnect the cable from the motor and the helm. Then attach a rope to the transom end and pull the cable towards the helm. Attach the rope to the new cable and feed it back through.
rob 135
Re: Steering cable
When I bought boat steering was frozen . I got it unstuck and kept turning wheel back and forth . Steers ok . There is a hole were cable comes threw but didn't want to lift motor off .
boobie
Re: Steering cable
If you have to replace it, try it the way I said.
