steering cables swap
rpatton
I have a mid 70s johnson 70 and my question is are the steering cables universel from motor make to motor make. My 70 has a stiff cable and needs to be replace and my son has a cable off a mid 70s merc 115 , will it work if the length is corect or does each make have there own setup. Thanks
F_R
Re: steering cables swap
The cables are pretty much universal. Unless you have a really, really old one.
boobie
Depends on what kind of helms they both had.
rpatton
They are both racks. Guess the only thing i can do is check it out. Thanks
boobie
Hopefully you'll have no probs if they're are both racks.
rpatton
Since i have someone responding i have another question. Do all of the 70 johnsons have a tell tail to see if the water pump is working like the mercs do. If they do where is it i cant find it anywhere.
rpatton
70esl 75 b
J4284300
Hope that helps . I have no idea of the year. Thinking maybe a 1975
You just have to make sure it coming out the back i dont think they did that on johnsons in the 70 but look for hose
boobie
That mtr didn't have a tell tale. And It's a 1975 model.
