Steering 'Flop'
brodie123
While I have my bell housing off, I wanted to check for steering flop. When idiling along, the boat swings port and starboard.
The gimble ring has some play before engaging the steering bar - so the play is in the ring.
Is this common or do I have a problem that needs to be fixed? I'd say the total 'free' swing from left to right is maybe 1"
thx
Re: Steering 'Flop'
Ayuh,... If retorqueing the keeper bolts doesn't tighten it up,...
Yes, replace the Ring,+ tiller pin...
brodie123
Re: Steering 'Flop'
are they located behind the upper gimble hinge pin?
Re: Steering 'Flop'
'ell I don't know,... You haven't told Us what the heck you're workin' on....
brodie123
Re: Steering 'Flop'
lol - ya sorry. 1988 Mercruiser Alpha 1
Here's a picture of the upper gimble hinge pin where I can see play between the hinge and the gimble
Re: Steering 'Flop'
Ayuh,... That looks Very Worn,.... Replace it...
brodie123
Re: Steering 'Flop'
will do. I'm trying to identify the corect tool and process for replacement. The manual is a little hard to follow on this one.
From what I can see/read - it's a threaded screw inside the hinge?
Any help is appreciated here to get started/clarity.
brodie123
Re: Steering 'Flop'
ok - got my allan key in there to back off the screw - and she's frozen.
advice???
brodie123
Re: Steering 'Flop'
I've booked her into a marine shop to just get it done - no sense leaving it as is.
Curious - what exactly is the inside allan key screw for?
