minuteman62-64
Thread starter- Joined
- Apr 12, 2011
- 1,350
On the final stages of getting my boat back in service. Working on hooking up the new steering cable today. Doesn't look right.
Motor is 1982 30 HP Mariner. I pulled it back in April and took it to a mechanic to have it brought back to life. Unfortunately I didn't take a photo of the steering linkage in its original position. I've tried to re-assemble as I remembered it and in a way that seems appropriate.
The first photo shows the questionable area. If I tighten the bolt that goes through the ball joint all the way (thus bringing the ball joint up flush against the bracket), the bolt clears the tilt lever but the link binds against the bracket that (I think) would support the tiller handle if there was one. This prevents a full turn to port.
If I back the bolt out as far as I can, and still leave enough thread for the lock-nut, I have clearance for a full turn to port. However, the bolt through the ball joint hits the tilt lever.
The way it is shown in the photos the bolt through the ball joint is extended to the point where it just clears the tilt lever. This allows the link to just clear the tiller handle bracket. This seems like too close a clearance for both the ball joint bolt/tilt lever and the link/tiller handle bracket. Particularly with the motor running and a little shaking/vibration.
The only thing I moved when I removed the motor was to detach the ball joint and the steering cable connections for the link. The only thing I can think of that the mechanic might have moved would be the bracket that receives the ball joint bolt - however, it doesn't look like it was disturbed.
The remaining two photos show the general configuration of the linkage.
Does it look right? Am I missing anything?
