peterpagnott
- Joined
- Feb 15, 2004
- 26
This was not the best weekend on the water...More posts to come. My steering started to slip if I turned to port. Finally I lost all steering to port but still had starboard. Cable??
Thanks!
After reading some posts on iboats I'm thinking of upgrading to a dual cable unit. The motor is moving freely, so now I'm suspect of the entire sytem. does anyone know if it is possible to put a dual cable system on a 2003 150XL?
Thanks for the input, I am going to look at the Rack and Pinion. I pulled out the original cable last night and it seemed odd how it was run. It comes in from the transom and then does an immediate 180 degree turn around my oil tank. It then goes below the deck and up to the center console. When I replace it should I just run it up the gunwale into the console?
Thanks again for all the input
