Steering Removal and tilt tube problems.
Human84
hey first time working on a steering system. cable is stuck in title tube and was wondering if i take the tilt tube out to replace with the cable will the motor fall apart. looks like its the only thing holding the mid section together. its an early 90s 115hp mariner. Photo on 5-11-16 at 4.33 PM.jpg Photo on 5-11-16 at 4.33 PM #2.jpg Photo on 5-11-16 at 4.33 PM.jpg
GA_Boater
Welcome aboard.
Don't take the tilt tube out unless the motor is supported, otherwise the motor will fall off.
Soak the heck out of the cable with PBlaster or your favorite solvent. You may end up beating the cable out of the tilt tube.
Human84
ok so my thought was right about not taking that out. started soaking it with pb guess ill just have to be patient and let it soak over a few days. been lurking for awhile but just dove into a project so ill be asking a lot of questions!!! looking forward to all the info from all of you seasoned vets.
pontoonsaloon
Just went thru this with my pontoon. Soaking didn't help! I had to beat it out with a long spike used for landscaling timbers. It wasn't easy cause I didn't have a lot of room to hit it with my hammer,but I did get it out. When it was time to install my steering, we lifted the motor off the transom,turned the motor sideways and I took an industrial type wire brush (12ga)shotgun size hooked to my drill and sprayed pb blaster in the tube and brushed the hell out a the tilt tube,wiped it clean and applied marine grease to the tube. Slid the steering cable in, bolted the motor back on and all was fine! I did have another tilt tube located on Craigslist in case mine was too bad.
krakatoa
You have to lift the outboard just like the picturtes below, thgere is no need to use a hammer or go rude with it. There is no enough room to pull the the steering cable back, thats why its stuck.
krakatoa
You have to lift the outboard just like the picturtes below, thgere is no need to use a hammer or go rude with it. There is no enought room to pull the steering cable thats why its stuck.
