Steering Set-up
phipps
I wasn't sure where this really belonged, but since they are Johnson motors I put it here.
I have a pontoon with a 1996 28hp Johnson on it currently. I have purchased a 1971 60hp Johnson as an upgrade.
The 28hp has the steering through a steering tube on the transom mount. The 60hp does not. See pics below.
Is such a set-up possibly with 60hp or am I going to have to buy a whole new steering system for the 60?
Thanks,
Gary
R.Johnson
Re: Steering Set-up
The 60 does not have tilt pin steering, and it also has seperate mounting brackets on the transon. You will not a after market set-up.
Chris1956
Honorary Supreme Mariner
Re: Steering Set-up
Gary, it was hard to see if the tilt rod was hollow. It did not look like it. If the tilt rod is solid, you will need to buy a splashwell clamp(with a swivel joint) to hold the steering cable end. It is a standard piece for those OMC motors and is avail at Teleflex website and most marine stores.
