Hi Guys,
Ok, I took my 16ft Trihull out for the first time this past weekend and had a great time, though there were some minor problems.
1.) The steering slipped when I put a lot of pressure on it, I could feel the gears slip. I'm planning on making sure the gear housing is all tight by tightening the nuts. Hopefully that will solve the problem.
2) While at full throttle for a bit I lost RPM like it was starving for fuel. I was able to blow it out by reving the motor and then was fine, happened a couple of times. I noticed it doesn't have an in-line fuel filter, so I'll try installing one to see if it helps. The fuel might be bit old too.
3) The owner before me installed some seats in which case the screws were too long and went all the way through the bottom of the hull below the helm seat. I attempted to fill the holes with marine tek but after the trip I noticed where the screw holes are the Marine Tek came off. What are your suggestions for filling the screw holes in such a bad location.
Thanks,
rbbrox
Thanks,
rbbrox
