flyhigh123
Thread starter- Joined
- Nov 17, 2012
- 112
Engine is volvo penta, 7.4GL.
The drive ram has a plate that says SX-C1. I believe it was retrofited to a duo prop, but is orignally a SX.
Steering is cable with power assist.
I recently just replaced my power steering pump with a new volvo unit as we found a leak. I don't know if the new unit fixed the leak as I took it out last week and by mid day the steering was stiff again. . I added fluid into the reservoir this morning and started the engine.
From the power steering pump to the Ram, is it just 2 hoses or is there a cylinder or something in between?
i went to use the boat and the steering was frozen. I shut the engine off, removed the steering helm, and tried to manually push the outdrive. At 1st it was stuck frozen. Shut engine off, then waited 30 minutes. Tried to push the outdrive again and this time, it moved. I was able to push it to one side, but while pushing to the other side, it locked up again.
Is this something with the power assist? After that the outdrive no longer would move when pushing it with the engine off or on.
I'm really not sure.
Thanks!
Thanks!
