steering
Woodonglass
Re: steering
Need more info. Single cable? Distance from Dash to motor? Did Wheel Mount on same side as this one? Basically cable length is the issue.
00tjwrangler
Re: steering
Idk I just seen an ad on a website for one I wouldn't mind buying brand New if it was to much I just was told the boat was set up to be a runabout boat and now is set up for tiller I sill have te steering wheel mount and throttle mount
Woodonglass
Re: steering
Goggle up how to measure for Cable Boat Steering. Too much cable length and too little is a problem. I pretty much has to be + or - 12" or it will kink and bind up on you and not be useable.
00tjwrangler
Re: steering
Ok thank you can u hooks steering up and everything to a tiller motor
ezmobee
Re: steering
Yep.
http://www.iboats.com/Corrosion-Res...5764940--**********.611379388--view_id.192758
