Step by Step removeal lower unit
liusigou
my boat is Mercuiser 2.5L,1989, the lower unit is leaking at the shaft pin. Do you have step by step to take the lower unit off from engine. I do not want to take the boat to the marine. Do you know how to fix it?
wellcraft-classic210
Hi -- Your going to need a good procedure from a manual -- its no too hard to pull a drive
// However repairing internal parts can require special skills and tools.
Here is a link to the online manual
http://boatinfo.no/lib/library.html
A few tips
Ensure the shift is in FORWARD or you can bend shift linkage related parts when pulling or installing.
SEI has affordable replacement drives that have good reviews should you choose to go that route.
Review the stickies at the top of this section and do a pressure test BEFORE disassembling the drive
Bt Doctur
either the driveshaft seals , or the water pump base seals.
either are easy enough for a beginer with the proper manual and coaching.
achris
More fish than mountain goat
I have a bunch of videos on different repairs, including removal of the drive. Click the ' My Videos' link at the bottom of my signature in this post..
Chris...
QBhoy
Presumably an alpha one gen 1 ??
are you sure it’s a 2.5l ? Not sure I’ve ever seen a 2.5l mercruiser from 1989.
It likely doesn’t have a gear oil header tank at that age...but if it does...remember and disconnect it before pulling the drive off.
QBhoy
Last year of the 2.5L was 1989...
Chris....
From Merc's EPC.
The very reason I’m on this forum most days. You think you are well versed...but always more knowledge to be gained on here !
achris
Currently watching a youtube series called PBS-Spacetime... If you want 'more knowledge', that is a really great place to start....
Chris..........
(but your head might explode. :boom: You have been warned!)
