Re: Steps to take to Salvage Old Motor
This is what I do with old motors (and I am always picking up old motors). I get some lube in the cylinders through the plug holes, and with a breaker bar on the flywheel nut, I rotate the engine by hand until it spins freely. Once that is done, I grab a portable tank, fresh gas/oil mix, and a charged up battery for electric start, and stretching excercises for pull start. I then pump the bulb. I am not concerned if the float works, fuel can dribble out of the throat for all I care, I just want fuel getting to all of the cylinders. I have been known to dribble some mix through plug holes just to get it to fire. I then attempt to fire it up in a trashcan of water on the off chance that the water pump will actually work (sometimes they actually do, I have been surprised). If it runs, THEN I am willing to spend money. It doesn't have to run great, it just has to run somewhat, and I only run it a short bit unless I can positively confirm the water pump is working. From there comes the compression check, carb cleaning, water pump impeller changing, lower unit servicing, etc. I do not want to do all that work on something that is all bollocks. Good luck...
