I have some questions on testing lower unit for leaks by spraying soap and water on seals. First, I do not think the leak is coming from prop area since I am seeing the oil coming from weep holes only. So my question is do I have to take the prop off to remove the lower case? I will be spraying soap on seals to see if I can find the leak. When I first take the lower unit off do I need to spray the soap somehere before removing the water pump? Once I remove the water pump will I be able to see the other seals below it enough so that when I spray I can see the bubbles? Are there other areas that I should spray that have seals besides under the water pump? Also since I am not doing a pressure test do I still need to put in 10psi?
Jerry, you had mentioned that you would give me some tips on what to do. I have never removed the lower case so any advice or warnings would be appreciated. I decided against going in and replacing all of the seals since I have never taken a whole lower unit apart before. RIght now I just want to find where the leak is coming from and replace the seal or oring and maybe inspect and replace any bad seals I see.(What do i look for in order to know seal is bad besides cracking and tearing) I will also replace impeller but have not purchased yet. I plan on starting this weekend. I have a 1989 Force 85HP.
