Stereo and AMP Power question????
ve3rpm
Re: Stereo and AMP Power question????
Wow! More than 30 years in the biz and I've never seen .707 X.707. You have to be kidding me. If you need to be that right, then go for it... Your ego, over doing the right thing... Knock yourself out. Sucks that you are willing to be right at the expense of someone looking for help.
TerryMSU
ve3rpm:
I do not know what business you are in, but it is not electrical (or electronic) engineering. Power is Voltage(RMS)*current(RMS). Peak power is peak volatge * peak current. The relationship for RMS is peak*0.707=RMS. This is true for both current and voltage. Thus the 0.707*0.707 mentioned above. My business is electrical engineering. I have a masters degree in electrical engineering and have been doing this since 1977. In addition, I teach electronics as a side-line business.
As far as Nate's original concern, 40 amps will be a bit much on any battery for 5 hours. Fortunately, you will not be drawing 40 amps continuously. Regarless of how loud you crank your system, there will be some relatively quiet intervals that will draw less than 40 amps. My seat-of-the pants guess is that you will be drawing closer to 25 or 30 amps on an average. If that 120 reserve is amp-hours, you will get about 3 hours of play time (or would from a brand new fully charged battery). Age and discharge cycles will reduce that substantially. Personally, I would get a big group 31 deep cycle battery and use that to power the stereo. Unless you are running the motor at near full throttle, you will not get much charging from the motor. You will need to charge the battery every time you dock it (or trailer it home) or the battery will not have a very long life. By that I mean charge it immediately after every outing.
TerryMSU
Ciera2450
+1 on the second battery! You don't wanna be stuck somewhere with a dead one!
I bet the infinity's sound great with the 60w rms amplifier!
Jerryh3
I think you may be a little out of your league..
j_martin
Nate's getting good help from others. I'm just running interference.
Have a good day.
bruceb58
At least he is right rather that what you are supplying!
Silverbullet555
Another question for this thread!! my new speaker/amp setup is complete. Four new infinity 4ohm speakers (225watt max) being powered by a (60watt rms x 4) marine amp. I currently have a dual purpose marine battery (120 reserve) and a jump pack on board. Again, i'm usually sitting on sandbars for about 5 hours with the radio going. The amp manual states that the maximum current draw is 40amps. Now i'm wondering if my setup will be good enough without a second battery or in your opinion i'll end up with a dead battery often.
People are getting testy on this forum.
Back to your secondary question, you won't be pulling 40 amps continuously as others have mentioned. I would recommend a second battery .Why? Because it is better to be safe than sorry. When I did my stereo upgrade, adding a second battery was part of the deal. Installed an ACR so both batteries are charged when the engine is running and they isolate when it is off.
